Got this,
But was going for this,
I'm looking for minimal work in the bathroom. The top row of vinyl tiles are mismatched replacements which may get painted to match the other black ones. I would like to gut the bathroom and start over but short on money and time/ideas.
There used to be a different mirror. I can move this one up and add the trim to achieve more of the late thirty's look.
The electrical available is on either sides of the mirror (you can see patches I threw on before I learned this is against code). It would be easiest to use these but not sure what kind of fixture would aesthetically work- seems most lights are above however this might aid in the retro look.
The only problem with the wires above the mirror is they are hot all the time and would have to be switched at the light.
I might have to go to electrical to ask how to reconfigure but would like to live with it to avoid the changes.
In conclusion the main issue is what type of side lights to use for this arrangement. Btw, it's the only bath for now with family of four, including a 9 and 10 year old girl and boy.
Was also considering Ralph Lauren suede on walls but have no clue what color to use with the tile.
Thank you for reading this. I appreciate any direction you could give on this and will try to keep up with further discussion.
