Accent Tile Placement? - Interior Decorating - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Interior Decorating
Old 06-18-2013, 09:40 AM   #1
mrs fix it's Avatar
Accent tile placement?
It's taken us a year but I think my husband and I have finally come to an agreement about our tile. My question for you all is....where would you put the accent tile? I'm planning on having it only 3 wide instead of the 5 (less busy for my husband ;-). Would you put it higher lower or center? My personal preference is leaning to center. Your expertise would be appreciated.
Accent tile placement?-image-2626553324.jpg   Accent tile placement?-image-3756993562.jpg   Accent tile placement?-image-3348486126.jpg   Accent tile placement?-image-1936445284.jpg
mrs fix it is offline   Reply With Quote
Old 06-18-2013, 10:13 AM   #2
Rewards Points: 297
You picked a beautiful tile for your granite.
I think center... the smaller tile directly over the granite is too busy.
Try putting two of the big tiles above the granite, then a row with three of the
small tiles, then the big tiles again. Use tape and arrange and rearrange it
until you like it.
Two Knots is offline   Reply With Quote
Old 06-18-2013, 10:31 AM   #3
mrs fix it's Avatar
Thank you for your quick response :-). How would you end the tile on far left, I won't have to worry about right because of fridge cabinet. Would you use a pencil/bullnose piece in neutral color? The upper and lower both end at same spot, for that I am glad. Your idea of two for starting row is a good one, after measuring window height, it comes to 5 1/2" off of counter. The two larger tiles plus two of the thin ones with grout is a shade longer. Hopefully this means I won't have to cut to much off of the thin ones.
Old 06-18-2013, 10:33 AM   #4
mrs fix it's Avatar
Sorry incomplete sentence....the upper and lower...cabinets ;-) silly me
Old 06-18-2013, 10:55 AM   #5
Rewards Points: 297
post a pic of the far left...do they have a bullnose tile for the larger tile?
Old 06-18-2013, 11:24 AM   #6
mrs fix it's Avatar
As to your question about the bullnose, they do but I haven't picked up any samples yet. That will be my next shopping trip now. I will play with a variety to see how it looks and post photos as well.
P.S. thank you, I LOVE my granite as well, I picked the tile so the focus will stay on the pretty movements in it.
Accent tile placement?-image-4131354023.jpg   Accent tile placement?-image-161196924.jpg
Old 06-18-2013, 11:59 AM   #7
Rewards Points: 297
yes, bullnose would be the best ... in the lighter color tile.
If they didn't have the bullnose, I was going to suggest making
your own bullnose molding stained to match the cabs...and
letting the the tile die into it; but my first choice would be
the bullnose tile.
Old 06-19-2013, 12:45 PM   #8
I would keep the accent tiles just below the window sill so the band will continue throughout the splash, I would think 2 to 3 rows of field tile and cut the accent tile to 3 or 4 rows so the top ends just below the window sill. Also I would stop at the left end of the upper cabinets. I think 5 rows is too much, 3 to 4 is plenty to create a nice accent.
mrwoodty is offline   Reply With Quote
Old 06-26-2013, 07:19 AM   #9
Great combination of granite but I think you have a problem about that tile.What is the name of the accent tiles used in your kitchen?
Existing tile, there is no reason you can't replace it with whatever tile fits there. My understanding is that it can be tough to remove the tiles without breakage though.
katypaver is offline   Reply With Quote
Old 07-07-2013, 06:48 PM   #10
mrs fix it's Avatar
Thank you all for your advice and help. I decided against doing any accent tile, fear of hating it in 5 or less years. So I went with a 3x6 travertine in a brick pattern. All I have left to do is grout. 😄😄
Accent tile placement?-image-609977559.jpg   Accent tile placement?-image-636877777.jpg   Accent tile placement?-image-3269694889.jpg   Accent tile placement?-image-801221044.jpg
Old 07-07-2013, 09:25 PM   #11
Looks fantastic, more pics after grout please.
Old 07-10-2013, 10:45 PM   #12
mrs fix it's Avatar
All done, taking tomorrow off! The outlets can wait till Friday 😊
Accent tile placement?-image-1304317529.jpg   Accent tile placement?-image-2857256893.jpg   Accent tile placement?-image-952864001.jpg
Old 07-18-2013, 04:11 AM   #13
Rewards Points: 297
Looks wonderful.
Help! Wall Tile Repair with No Substrate? LauraFixItGirl Tiling, ceramics, marble 4 06-06-2013 11:05 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
