You Win Guys - Hardwood It Is! Two Questions. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 03:11 PM   #1
Rewards Points: 27
You win guys - hardwood it is! Two questions.
Hi all,
ok, so I made a post before about laying laminate over an existing hardwood floor. The post is HERE.
After MUCH deliberation I have decided to go with hardwood. I have 2 questions if that's all right.
1. Looking at 3/4 inch thick, but I am also wondering if thinner matters? My concern is stability. If I can use a thinner board it would help with the levels.
2. Should I cross lay with the existing boards? I wonder if that will be more stable in the long run.
Oh, the floor of choice is BR-111 Tiete Rosewood. If anyone has any comments they would be welcomed.
Thanks a lot!!!!
Hugh
hugh71158 is offline   Reply With Quote
Old 03-04-2010, 03:20 PM   #2
i helped a friend install a prefinished bamboo floor after removing carpet. i believe it was 5/8 we nailed it with a power nailer using staples. made for a nice stiff floor
The older I get the better I was
Old 03-05-2010, 07:31 AM   #3
Do not lay new hardwood floors over your old hardwood oak flooring.
Do it right and pull up the old before adding the new.
Lay the new flooring over the subfloor, perpendicular to the floor joists.
Dairylander is offline   Reply With Quote
Old 03-06-2010, 08:36 AM   #4
Rewards Points: 162
I would also recommend getting down to the original subfloor. If your floor has any creaks or groans right now, adding a second layer of hardwood is going to make it worse. Get down to the original subfloor and screw down any loose boards.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 03-07-2010, 09:47 PM   #5
Rewards Points: 27
thank you gentlemen - out with the old it is then!
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Basic questions for hardwood or laminate install Demus Flooring 3 01-17-2010 06:38 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Questions on Staining Hardwood! noodlesalad Flooring 2 12-15-2006 09:17 AM
Hardwood floor questions KUIPORNG Flooring 4 11-09-2006 08:08 PM
