Yile Over Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2008, 10:56 PM   #1
yile over vinyl
with wood sub-floor, covered w/vinyl, can i lay hary board over vinyl?
tomholtz@bellsouth.net is offline   Reply With Quote
Old 02-19-2008, 03:26 PM   #2
I'm guessing hary board = hardy board. Tile should NEVER be installed over vinyl or luan. Vinyl/luan plywood will compress over time in high traffic areas and cause the tile to fail. Even with hard board/durock/plywood over the vinyl or luan. I think the only way I would give it a go ahead is if concrete was poured on it and ditra was used. Some people will give you the go ahead but I have seen this done and fail many times.
I did a small article on my website about this very subject.
http://forum.creativecoveringsolutio...topic.php?t=12
Adam Forsythe
CCSowner is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
