[quote=loomis1228;66285]Hello everyone,
My name is Jesse Gabbard and I'm from Lexington, KY. UK plays South Carolina tonight to see who takes over the top spot as #1 in the SEC East. Go cats!
This weekend, I am installing Shaw Laminate. A few questions:
1) Is this brand ok?
2) The subfloor is wood (over a basement) and it is pretty wavy. Should I add filler and sand the surface before installing the flooring? Or would it be ok to just put the foam underlay and then the flooring?
3) I am going from Bruce hardwood flooring (3/4" prefinished wood) to laminate and am concerned about the transition between the 2. The hardwood has a, I guess you would call it, beveled edge. Is the transition strip going to be enough to cover this?
If I understand it correctly, you are not installing in a basement, but, on the first floor above the basement. If so, no barrier is needed. Let us know how it goes.
