Yet Another Laminate Stairnose Dilemma - Flooring - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 11:36 AM   #1
jkk
Rewards Points: 233
Yet another laminate stairnose dilemma
Laying laminate after adding 1/2" plywood to eliminate transitions at tile interfaces. Plan for stairs is to carpet them, or install new stained treads & risers, or ... Something else.
Of course one problem is the extra height added from top step to floor. Used to be 8 3/8", now it'll be 9 3/4" (1/2" plywood, 9/16 bullnose, 5/16 laminate). The other step heights averaged 7.5".
Question #1. For the previous height difference, is it normal to have the top step height to be 8 3/8" while the other steps are 7.5" ? Or did the builder make a mistake, maybe by not accounting for 3/4" sub flooring in his stringer calculations?
Question #2: What is typically done for these steps when height is added?
Question #3: How to accommodate the added first step height? I could shim/stub the treads, transitioning from bigger shim at top step to smaller shim at bottom step. Would not have uniform step heights but height difference between 2 consecutive steps would only be 1/8".
jkk is offline   Reply With Quote
Re-using laminate wingman1153 Building & Construction 10 04-30-2013 12:51 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
