Old 02-19-2008, 12:08 AM   #1
Question
yellow carrera marble?
Help! Whats happening with the new carrera marble?
marble is offline   Reply With Quote
Old 02-19-2008, 07:09 PM   #2
Is it in just that one piece? It could be everything from the thin-set used to the sealer used to it came like that.
CCSowner is offline   Reply With Quote
Old 02-19-2008, 08:35 PM   #3
Tileguy
Bud Cline's Avatar
marble,
If you seriously want some answers or opinions you need to offer more information. How can anybody make any educated guesses with only what you have posted?
Code:
1. How long has it been like that?
2. Did it happen suddenly or grow over time?
3. Is the entire floor area like that?
4. What is the substrate wood or concrete?
5. Has the floor ever been flooded?
6. Do you live in the city or the country?
If you could just answer three out of the six questions we may be able to help.
Old 02-19-2008, 10:29 PM   #4
Tile Contractor
Bill_Vincent's Avatar
Quite honestly, that doesn't look like a new slab, but even if it is, it can be one of two things. First, it can either be rust from iron in the stone, or it can be a stain from a wood "A-frame" that the slab might have been sitting on for a period of time. Before anyone could say for sure, though, as Bud said, we need more info.
Start splainin!!
"Whether you think you can, or you think you can't, You're probably right."
Bill_Vincent is offline   Reply With Quote
Old 02-20-2008, 09:54 AM   #5
yummy mummy's Avatar
Bill
I just took a look at your pics. VERY NICE, work.
yummy mummy is offline   Reply With Quote
Old 02-20-2008, 11:13 AM   #6
Tile Contractor
Thank you.
I fake it real good.
Old 02-22-2008, 06:16 PM   #7
3-5 months.
It started to be yellow after some few weeks on the dry but new concrete surface below. We do not know if it's caused by the marble as it's shipped or if it's water and other chemical components from the concrete in combination with long dry time. The problem is bigger inside the building than outside.
No. Big parts are.
Concrete. Cure time of concrete was a lot longer than normal to be sure it was dry enough.
It was cleaned with some water once. Then covered with wooden plates for months for protection.
Picture of building:
http://www.bygg.no/image/2573/1/4/2573_1.jpg
http://cache.aftenposten.no/multimedia/archive/00643/_23112007175654_jpg_643352s.jpg
All the white is this type marble...
The marble order was about 10 million dollars. The floor is huge...
The building cost more than 7.5 billion dollar
Suggestion: Yellow may be pyrite oxidation (rust)
Suggestion to solve problem:
Creative Covering Solutions
www.CreativecoveringSolutions.com
Product: http://www.prosoco.com/ProductDetail...3D513C6C4FB%7D
Old 02-22-2008, 07:25 PM   #8
Tile Contractor
As good as the product is that Adam suggested, different stains clean up better with different poultices. Now, my first reaction when I first saw the stain was rust due to iron in the stone. Problem is there's a pattern of sorts to it, which then leads me to something the stone may have been leaning against, or that may have been laid upon it, such as rough hewn wood on top of it, or leaning it up against a wooden "A"-frame, meaning it could be a "sap" stain. Both of those would require different poultices.
That's about the extent of my knowledge. My suggestion would be to talk to someone who specializes in stone restoration.
This restoration forum would be a good place to start:
http://johnbridge.com/vbulletin/forumdisplay.php?f=16
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 06:22 PM
How can you cut marble round a fireplace stu_mchugh Remodeling 1 02-17-2008 02:11 PM
marble refinishing glenn1644 Flooring 2 08-10-2007 10:09 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 01:27 PM
