Yack! My Tiles Are Stronger Than My Walls! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-07-2008, 11:32 AM   #1
Yack! My tiles are stronger than my walls!
Apologies for barging in here with a question straight away.... I failed on my third day of my plan to become the ultimate self-reliant DIY-queen so I'm desperate!
I live in a "cardboard house" - most interior walls are plaster, and really crap ones at that. I need to remove some tiles from my (plaster) bathroom wall and basically if I go at them with a chisel / spatula / anything, the wall caves in before the tile does! (the adhesive seems really strong too)
How can I get these off (it's only like 3 half tiles and some leftovers) without ending up getting my whole wall redone?
Many thanks!
ClarissaWAM is offline   Reply With Quote
Old 04-07-2008, 04:50 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You should be able to pry the tiles off the wall without causing that much damage if you use a wide 3-4 inch rigid putty knife and a hammer.
If that doesn't work for you you'll just have to bite-the-bullet and make the necessary repairs after the tile is out.
Old 04-08-2008, 01:12 PM   #3
Thanks for your reply. Yes I have tried that and that's exactly where the wall caves in before the tile will come off.
But I've resigned myself to some messy repairs. Thanks for your help.
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Slate tiles on floor and walls Mr Chips Flooring 8 04-09-2008 06:49 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
