Wow - I See Why People Don't Use Plywood As Basement Subfloors - Flooring - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 10:28 PM   #1
Rewards Points: 264
Wow - I see why people don't use plywood as basement subfloors
I am framing my basement and threw a couple pieces of plywood on the floor so I'd have something to assemble the sections on. That was about two months ago, and I noticed white mold growing on the tops of the boards.
I picked the boards up today - looks like something you'd see on Hoarders! Just solid green and white mold. Imagine if that had been a subfloor - by the time it came up and ruined whatever was on top of it, your whole basement would need torn out and bleached.
Just though I'd share, in case anyone is thinking about using plywood subfloor over their concrete. I'm not sure I'd even trust a plastic moisture barrier, cause one hole and your back to mold eating your floor.
tibberous is offline   Reply With Quote
Old 08-19-2011, 03:06 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Don't even need a hole in the plastic. Mold will grow under it,
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-19-2011, 08:28 AM   #3
Rewards Points: 93
I guess it depends on the amount of moisture in the basement? I have plywood subfloor on top of Delta-FL. It has been fine.
leungw is offline   Reply With Quote
Old 08-19-2011, 09:49 AM   #4
Rewards Points: 14
For how long? And if you can't see under it, you can't be sure there is no mold.
Old 08-19-2011, 10:21 AM   #5
Rewards Points: 93
Yes, I cannot be 100% sure. The subfloor was installed in the beginning of this year. I still don't have anything on top of the plywood yet, so I can only inspect the top side.
Prior to that we had been using the basement strictly for storage. Cardboard boxes were stacked on the concrete floor for years. When we moved the boxes upstairs, the bottom of the boxes were all clean. So my basement seems to be very dry compared to the OP's basement.
Best Way to Dehumidify Basement? ntauctions HVAC 9 05-31-2013 02:36 PM
Putting up 2 walls in basement using PVC as frame. MiriamP Building & Construction 31 08-05-2011 10:24 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
