-   -   Would you staple, nail or screw? (http://www.diychatroom.com/f5/would-you-staple-nail-screw-31873/)
Speedball 11-14-2008 06:32 PM
Would you staple, nail or screw my 1x6's to the floor joists so I can continue on with the next layer?
I can buy a really cool Senco stapler that would work well with my compressor.
... or I can buy some ring shank nails and do it the old fashioned back breaking way.
... or borrow my neighbors Senco screw gun. The reason I hesitate to try the screw gun is so many screw heads blocking the next layer of flooring.
...................:help:
buletbob 11-14-2008 06:54 PM
glue and nail. then install the next layer with screws. BOB
JazMan 11-14-2008 07:35 PM
Sounds to me you are not installing new 1x6 but re-fastening them preparing for the underlayment. If so, too late for glue. What kind of underlayment are you installing? What will the final floor covering be? The answer may make a difference on how the underlayment is installed.
Jaz
Speedball 11-14-2008 09:00 PM
You're right Jaz, the 1x6 is existing. I haven't exactly decided what the floor will be in all the rooms but I sort of thought I could start off with 3/4" as a nice solid quiet layer to begin with, then add layers if needed for thinner floor coverings.
My neighbor thinks I should just use his screw gun to re-anchor those 1x6's but I'm afraid the wood is so dry all the ends will split or the head will not be flush. That's where the staple gun idea comes in.
JazMan 11-14-2008 10:00 PM
Screwing is the best way to go, but you may have to pre-drill to avoid splitting the old boards? Nailing with 8D deck nails is also very good. The stapler may also work if the staples are rated for this type of work. Which model do you own?
Adding 3/4" underlayment over your 1x6 will give you a good subfloor from which to work from regardless of the new flooring. BUT, have you consulted a span chart to see if your joists system can handle certain types of tiles or natural stone tiles? That's what I thought. If you go with ceramic or stone tiles we need to know all about the joists just to make sure.
I asked about the type of flooring because with some flooring it is recommended that the new underlayment NOT be fastened to the joists, but rather just to the subfloor. The an appropriate backer board would go over that.
Jaz
Speedball 11-15-2008 06:11 AM
The entire home will be carpet, vinyl of some sort or maybe even a floating floor somewhere. Senco sells a stapler that shoots 7/16" x 2" crown staples which I guessed would work well.
...thanks.
seanJohn 11-15-2008 02:40 PM
staple
The crown stapler should do the trick.
chad4290 11-28-2008 11:21 AM
a 1/2 inch 2 inch staple should be good with pl400 then screw down the next layer
