Would You Replace This Subfloor? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 01:22 AM   #1
Would you replace this subfloor?
I'm remodeling my laundry room including new floors. When I moved the W&D I found evidence that there was a lot of water damage in my home's past. After removing all 3 layers of vinyl and the particleboard underlayment, I'm down to the subfloor. Generally, the subfloor seems in good shape. At some point, somebody drilled two holes through the subfloor and the surface of the plywood flaked off from the water damage.
The subfloor is 1/2", I'm planning on putting 1/2" plywood underlayment and then Flexitec/resilient flooring. I read somewhere that if the subfloor isn't bouncy then it is structurally sound. I can stand/walk on this corner without any give in the flooring, there is a joist that runs 4" away from the back wall which probably helps. My joists are 24" OC, so if I replace the subfloor it will mean adding a lot of extra blocking. I'm planning on putting a stacked W+D in this corner where previously it only had a washer (the dryer was next to it).
So, what do you think? Do I need to replace the subfloor?
What you see in the photo is all the loose pieces and debris completely removed.
http://yfrog.com/mr5hf0j
winterminute is offline   Reply With Quote
Old 11-30-2010, 05:50 AM   #2
KCB
I wouldnt as long as its not rotted its fine.Some 1 had a similiar question and created a big problem/ mess by cutting 1st asking later.
KCB is offline   Reply With Quote
Old 11-30-2010, 11:48 AM   #3
I agree
warnerww is offline   Reply With Quote
Hardwood installed, subfloor too thin, help! smon Flooring 2 09-30-2009 09:36 AM
Subfloor Help Tom5151 Building & Construction 16 09-24-2009 01:33 PM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 10:06 AM
