Would Peel And Stick Tile Stick To Tar Paper? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 02:49 PM   #1
Rewards Points: 452
Would peel and stick tile stick to tar paper?
For a rental property, I was thinking about making a floating peel and stick floor from fakewood peel/stick vinyl plank over sheets of tar paper.
I don't want to stick vinyl tile directly to the concrete slab because it would be a bish to remove later, and the roughness of the slab would not allow for good adhesion anyway.
If not tar paper, then what?
This would be in the living room and hallway. All the other wet areas already have ceramic tile.
pman6 is offline   Reply With Quote
Old 06-28-2013, 03:14 PM   #2
if you want a floating floor go with laminate or engineered. peel and stick over tar paper would be a disaster unless you like doing the floor twice.
Old 06-28-2013, 04:04 PM   #3
Rewards Points: 452
i was trying to stay away from laminate because i know tenants are careless with spills. otherwise it would be my first choice
Old 06-28-2013, 07:31 PM   #4
Rewards Points: 13,750
Peel and stick is by far on of the worst types of flooring you can buy.
Old 06-28-2013, 07:43 PM   #5
Framing Contractor
Rewards Points: 120
Try using a vinyl plank floor. Lays just like the laminate, but is 100% vinyl.
sixeightten is offline   Reply With Quote
Old 06-28-2013, 08:10 PM   #6
Go with tile or get loose lay vinyl which is one piece of vinyl that you dont glue amd comes in many styles.
Fiveash is offline   Reply With Quote
The Following User Says Thank You to Fiveash For This Useful Post:
joecaption (06-28-2013)
Old 06-29-2013, 12:58 PM   #7
Rewards Points: 6,652
You are making an assumption and creating a stigma that all renters are the same. Being cheap and making it look cheap, will end up turning away business, due to it will show that you do not care.
As for laminate flooring, there are different grades. Go with commercial type flooring if you want something that will last, not something you just picked up off the remnant rack at the big box.
Old 06-30-2013, 07:01 AM   #8
Greg makes a very good point. While a little more expensive, a commercial grade linoleum stands up to the abuse of hundreds of people daily.
creeper is offline   Reply With Quote
Old 06-30-2013, 08:48 AM   #9
Remodeling Contractor
If I walked into a potential rental home and saw that the landlord was this cheap to install peel and stick over felt, I would walk. There is a BIG difference between
"cost effective" choices and "cheap." Buy a product that will last and you won't be doing this floor again for a while. For what it's worth, floating laminate or engineered wood WILL hold up under traffic and like was stated already, don't assume everyone will beat up your house and not care about the conditions THEY live in.
Phil,
http://www.edgestripkits.com
pgc555 is offline   Reply With Quote
Old 07-01-2013, 01:25 AM   #10
Rewards Points: 452
I don't assume. I've SEEN it in the past 20 years of renting out my house. Only 1 out of 10 people keeps my floor clean.
The other 9 live like animals almost, and they're fine with it.
Old 07-01-2013, 02:34 AM   #11
It's good to go with an upscale vinyl ; its easier to replace and doesn't cost a fortune.
Evie traacy is offline   Reply With Quote
Old 07-01-2013, 07:48 AM   #12
You are renting to the wrong people.
Old 07-01-2013, 10:29 AM   #13
Rewards Points: 3,130
Yeah, no kidding.
Peel and Stick over this type of tile....? Rebelatheart Flooring 6 08-20-2012 02:05 PM
Removing peel and stick tile adhesive in preparation for tile stubborn1 Flooring 3 01-09-2011 01:34 PM
Peel and stick tile. remarc Flooring 2 07-20-2010 05:24 PM
Peel and stick vinyl flooring over absteos tile? Codchamp Flooring 3 07-17-2010 06:17 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
