Old 05-22-2012, 11:09 AM   #1
Worth paying for wet grinding glue off concrete lanai?
I have a concrete staining company that will prep my 9x20 ft lanai for staining by wet grinding the glue left on after I pulled up outdoor carpeting for $270 so I can stain it myself or I can pay them an extra $500 to stain it for me. Money is tight and i have tried to remove the glue myself with solu-strip but can't so I am considering paying for the prep only. Is concrete staining really something I can do myself or am I kidding myself? I saw quikrete at lowes
Flhome is offline   Reply With Quote
Old 05-22-2012, 05:30 PM   #2
$270 to remove the glue that you can't otherwise remove with chemical stripper doesn't sound like a bad deal at all. Especially, when you factor in the tools, time, and experience the contractor has (should have, anyhow).
Concrete staining usually involves applying an acid to lightly etch the surface, and applying the stain. Doesn't sound too hard. I'd save the $500 and do that part myself.
you saw quickrete at lowes....so....are you staining an existing or pouring new?
Seattle2k is offline   Reply With Quote
Old 05-22-2012, 05:47 PM   #3
Thank you for the reply. I am planning on staining existing concrete.
Old 05-22-2012, 07:55 PM   #4
Super Moderator
I suggest you do not use any solvents---the solvents will soak the glue deep into the porus concrete---
Might cause the stain to be blotchy and uneven---
rusty baker (05-22-2012)
Old 05-23-2012, 12:02 AM   #5
a thought came up...you might try renting (or buying at harbor freight) a handheld grinder and putting a steel wire brush wheel on it. That might remove the glue, if you're wanting to trying DIYing that part.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Removing glue from concrete? Ike64 Tiling, ceramics, marble 1 09-26-2009 03:28 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
grinding concrete amakarevic Building & Construction 1 08-14-2007 09:09 PM
