Is This Worth It? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 11:43 AM   #1
Is this worth it?
So I am looking into my sub floor for the basement revamp I am doing... I want to lay down a nice sub floor... I already have the floor foam board insulated and I am looking at even going a step farther and using Dricore 2x2 sub floor... please have a look http://www.lowes.com/pd_173869-21607-0001_0__?productId=1043515&Ntt=dricore+2+x+2&pl=1 tURL=%2Fpl__0__s%3FNtt%3Ddricore%2B2%2Bx%2B2&facet Info=
Should I go this route or just go the typical plywood route... I live in PA so it does get humid here... and I am not using a vapior barrier... but I want to take any step now to protect my basement investment.
Let me know what you think.
Matt
thetroups is offline   Reply With Quote
Old 05-16-2012, 11:59 AM   #2
Rewards Points: 13,250
Dri-Cor would be the way to go just very expencive.
You can not directly attach plywood to a slab floor, it will rot and form mold under it.
Why no vaper barrier?
Old 05-16-2012, 12:05 PM   #3
not suppose to use vapor barrier in a basement ...
Old 05-16-2012, 02:22 PM   #4
There "SHOULD" be a vapor barrier under the basement slab.
UFoPilot is offline   Reply With Quote
Old 05-16-2012, 02:35 PM   #5
all the research I have done that goes both ways... and the product I showed above would not require that... also my vapor barrier is the foam I put on the floor... so technically I have one... just not a heavy sheet of plastic... and this does not answer what this post is about.
Old 05-16-2012, 03:49 PM   #6
Rewards Points: 3,406
That all depends on the year of construction.
Canarywood1 is offline   Reply With Quote
Old 05-16-2012, 04:03 PM   #7
the house was built in 1991
Old 05-16-2012, 08:28 PM   #8
Should have a vapor barrier then.
Old 05-17-2012, 02:19 AM   #9
Is it recommended to install dricore over foam? I would check on that before I installed it.
when is it not worth fixing? roadgypsy General DIY Discussions 12 01-13-2012 04:04 PM
Making Your Own Pavers... Is It Worth It? Thadius856 Landscaping & Lawn Care 8 08-27-2011 11:53 AM
Sound Isolation Clips (worth the money) nsanto17 Building & Construction 7 12-31-2010 11:22 AM
worth insulating pipes? wombosi HVAC 4 02-15-2009 07:32 PM
what is the wire worth dzg123 Electrical 22 08-31-2008 09:56 AM
