Worms Under Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 11:14 PM   #1
Worms under wood floor
I have engineered wood floor installed over slab floor about 4 years ago. recently i found some areas where the wood became darker and swollen. when i opened one area, i found white little worms, don't know what are they, and how to resolve the problem, a wood floor installer concluded the is no leak under the concrete, and these are not termites.
can you help?
thanks very much
Izzy
izzynagar is offline   Reply With Quote
Old 05-19-2011, 03:52 PM   #2
Rewards Points: 1,558
Most worms are not white; may not be termites but google termite and select images. You'll quickly see if they are or not. Also, could take some to a pest control place who likely can tell you quickly.
bob22 is offline   Reply With Quote
Old 05-19-2011, 05:54 PM   #3
woodman58's Avatar
Sounds like termites to me. You definetly have a water problem.
woodman58 is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Wood floor on a tongue & groove subfloor. Huckleberry Flooring 4 05-10-2011 09:41 PM
need advise on refinishing a wood floor EPERRINGTON Flooring 2 03-13-2011 09:12 PM
Wood Floor in my new shed butlerguy1990 Flooring 3 08-07-2009 10:37 AM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
