Old 08-02-2007, 07:18 PM   #1
Workshop floor
I've built a shed to do some woodworking. It's all wired and now I'm wondering what to cover the floor with(if anything). The floor is 4x8 sheets of plywood. It's not on a concrete pad. I have some machines on wheels which need some friction for the wheels to turn. I'm all ears !!
gmjosey is offline   Reply With Quote
Old 08-02-2007, 07:33 PM   #2
Home Improvement Guy
ron schenker's Avatar
Workshop floor
How about a commercial grade 12"x12" linoleum tile. Cheap to buy, easy to clean, easy to install, looks pretty good, and has some traction.
ron schenker is offline   Reply With Quote
Old 08-02-2007, 08:09 PM   #3
Agent 000
SecretSquirrel's Avatar
Workshop floor
Ron's idea of linoleum is a good one but only if the temperature remains fairly stable in the shop and it doesn't get cold in there. Else, the linoleum gets brittle, cracks, separates, whatever. In other words, linoleum doesn't like wide temperature swings.
In my storage shed with 3/4" plywood flooring I put a good coat of primer down then followed up with 2 coats of gray porch enamel. If you need some grit then you can add some of that material that they use for garage floor stain. I know Sherwin Williams has something called "Shark's Teeth" that they add to their H&C stain to give the floor a little "tooth".
SecretSquirrel is offline   Reply With Quote
Old 08-02-2007, 09:41 PM   #4
Workshop floor
Yeah,Squirrel,I was thinking along those lines. I'm in an area where the temp goes from a high of plus 34C down to minus 25C. Thanks for your input,guys.
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 02:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 04:25 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
