Old 08-07-2009, 06:49 AM   #1
woodstove hearthpad on laminate floor?
Going to get a woodstove put in in the next few weeks. Where it's going currently has laminate flooring that's still in pretty good shape, so I'm reluctant to cut into the laminate to remove it for hearthpad placement, especially since I may take the stove with me when I move. And because I will probably want to take the stove and pad with me, I'd like to protect and preserve the flooring under the hearthpad.
I'm thinking of building a hearthpad, probably 3/4 OSB, maybe with a 2x2 or 2x4 frame underneath, wonderboard, and some sort of inexpensive non-flammable something on top. But there's also the possibility I'll run out of time and just buy a hearthpad.
So what should I put between the hearthpad and the laminate floor to protect the laminate floor?
jeauxbleaux is offline   Reply With Quote
Old 08-07-2009, 08:46 AM   #2
HABSFAN2006's Avatar
doesn't matter.. even if you don't scratch it, there will be discoloration that will be noticeable when you remove your stove...
Life is an experience... Learn from it!
HABSFAN2006 is offline   Reply With Quote
Tags
floor, hearth, laminate, woodstove
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Laminate floor direction in an L shaped space yesicamiranda Flooring 3 07-16-2011 08:53 PM
I want to install laminate plank flooring but have problem with sub floor In the Bush Flooring 3 04-29-2009 01:35 PM
Laminate Kitchen Floor Rawhide Flooring 8 01-05-2007 07:52 PM
Floor spacers when installing laminate floor flybynite Flooring 4 12-04-2006 10:24 PM
