Wooden Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 06:23 AM   #1
wooden floors
Can yu use liquid nail to glue down hardwood floors. If so what kind, or what would you suggest.
pgeoghegan is offline   Reply With Quote
Old 08-10-2012, 06:40 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 110
You can do what you want. It won't work, however.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-10-2012, 08:29 AM   #3
Rewards Points: 13,694
Why would you want to?
Are you trying to install it over a slab?
Old 08-10-2012, 02:23 PM   #4
Rewards Points: 264
Solid wood floors that are 3/4" can not be glued down over a concrete slab. Engineered hardwoods can however be. I would suggest Bostiks Best glue, it is a vapor barrier and glue in one. Be sure to check the moisture levels in the concrete prior to gluing a wood floor to it. You can do this with a calcium chloride test. These can be found online. If you have a plywood subfloor, I would staple rather than glue as it is easier and it saves the cost of glue.
Awoodfloorguy is offline   Reply With Quote
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Refinishing old wooden floors - Sanding Procedures Sartrean Flooring 2 01-18-2012 06:55 AM
Engineered wooden floors gfulginiti Flooring 2 05-31-2011 07:28 PM
Repainting wooden floors MaryCooksalot Painting 4 10-06-2010 09:23 PM
Any idea how to remove glue from wooden floors tash08 General DIY Discussions 5 10-29-2008 06:24 PM
