-   -   wooden floors (http://www.diychatroom.com/f5/wooden-floors-153212/)
pgeoghegan 08-10-2012 07:23 AM
wooden floors
Can yu use liquid nail to glue down hardwood floors. If so what kind, or what would you suggest.
rusty baker 08-10-2012 07:40 AM
You can do what you want. It won't work, however.
joecaption 08-10-2012 09:29 AM
Why would you want to?
Are you trying to install it over a slab?
Awoodfloorguy 08-10-2012 03:23 PM
Solid wood floors that are 3/4" can not be glued down over a concrete slab. Engineered hardwoods can however be. I would suggest Bostiks Best glue, it is a vapor barrier and glue in one. Be sure to check the moisture levels in the concrete prior to gluing a wood floor to it. You can do this with a calcium chloride test. These can be found online. If you have a plywood subfloor, I would staple rather than glue as it is easier and it saves the cost of glue.
