Wood To Tile Transition? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-15-2007, 10:02 AM   #1
Rewards Points: 152
Wood to Tile transition?
I am laying Pergo wood floors and Columbia Slate laminate floors.
What is the best way to transition between this?
sandyman720 is offline   Reply With Quote
Old 10-15-2007, 10:12 AM   #2
If the finished floors are the same height, i'd put in a wood t-molding to match the wood floor.
NateHanson is offline   Reply With Quote
Old 10-15-2007, 11:56 AM   #3
A T-Mold would be your best option considering both floors have to be able to expand and contract along with some shifting from time to time.
Make sure the T-Mold is not tight against either of the two floors, but yet covers up the edge of both floors.
The T-Mold should snap into a plastic channel that has to be screwed to the subfloor.
KenH83 is offline   Reply With Quote
Old 10-15-2007, 01:30 PM   #4
I put the "why?!" in DIY
If they aren't the same height you should be able to find something here:
http://www.tools4flooring.com/moldings-c-106.html
These aren't real fancy, just basic metal transitions but they do the job cleanly and nicely. I've used them for laminate to tile and laminate to carpet transitions when the floors are on a different level.
In some cases I have screwed/nailed them to the subfloor, and in others I have actually drilled pilot holes and screwed them right to the laminate flooring and let the other edge "float" over the tile/carpet. This still allows both floors to expand/contract as needed.
But, if you're willing to spend the money, the matching reducer transition for your laminate floor would be ideal.
jmancine is offline   Reply With Quote
Tile vs Wood as a baseboard MattCoops Flooring 14 11-12-2014 04:26 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Tile with a wood appearance? jerome8283 Flooring 2 11-15-2006 07:53 AM
Tile Walls - Wood Floors - which goes first? MikeinBurien Flooring 1 03-04-2006 07:55 PM
