Wood Subfloor Expansion/contraction - Flooring - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 11:04 PM   #1
wood subfloor expansion/contraction
Plywood subfloors might expand/contract by a few millimeters with humidity levels (right?). Doesn't that pose a problem for portland cement-based products, e.g. floor levelers? Why don't the cement-based products crack when the wood expands or contracts?
rogercaplan is offline   Reply With Quote
Old 12-18-2012, 06:54 PM   #2
Rewards Points: 744
Who said it won't?
Seattle2k is offline   Reply With Quote
Old 12-18-2012, 08:29 PM   #3
Originally Posted by Seattle2k View Post
Who said it won't?
I'm assuming it won't, based on the fact that there are many cement-based flooring products available that, according to the manufacturer, can be installed over plywood (and sometimes osb).
Old 12-18-2012, 09:38 PM   #4
Rewards Points: 744
It's likely to crack. What's more important is the type of finish flooring you'll be installing and the underlayment that goes on top of the cement leveller
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
