Wood Piece Underneath Front Door Sill - Flooring - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 03:00 PM   #1
Rewards Points: 154
Question
wood piece underneath front door sill
Hi all,
How do I remove the wood underneath the door sill in my front door? Do I have to take the entire door off including all the sides to access that piece of wood?
I need to replace it because it's very old. I have a raised porched with a wood deck.
Thanks.
llckll is offline   Reply With Quote
Old 08-25-2009, 07:12 AM   #2
I assume you have a rot issue that requires that to be replaced??? If it is a modern door, with the threshold as part of the jamb, yes, the whole door will have to be removed. If it is an older door with a separate threshold, just remove the threshold.
Tags
door sill
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
piece of horizontal wood through studs? yummy mummy Remodeling 13 11-24-2006 08:33 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
