Wood Onto Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 09:31 AM   #1
Wood onto ceramic tile
I need to secure a 1x6 piece of pine, 4 foot long to a ceramic tile floor, any suggestions on how to make it secure. Would liquid nails for marble work?
Coil41 is offline   Reply With Quote
Old 05-20-2011, 11:41 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
What is this for? Letting us know the purpose, what this will be used for, how strong it needs to be, etc. etc. will get you an answer that is best suited to your needs.
The Following User Says Thank You to Blondesense For This Useful Post:
Coil41 (05-21-2011)
Old 05-20-2011, 09:54 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Coil,
Like Blondy said, more info would help. But in general, I have secured 2 x 4's for cleats for kitchen islands with exterior grade deck screws and gone through the mortar joint, not the tile. This is also assuming there is a wood subfloor under the tile and it's underlayment.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Coil41 (05-21-2011)
Old 05-21-2011, 07:08 AM   #4
Adhere wood to ceramic
The wood will have a slot and newel attached that will be holding a piece of 3'x3' tempered glass, the other end of the glass away from the newel will be against the wall. Used for a decorative barrier next to a 5 step staircase going down.
Old 05-21-2011, 07:18 AM   #5
DIY staff
Rewards Points: 7,174
PL Premium is a good adhesive---To bad the newel couldn't go through the tile and be attached below the floor,into the framing--Is that still a possibility?
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 01:40 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
How to Prep wood floor for ceramic tile ? mgoose Flooring 8 08-16-2009 08:46 PM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 01:04 AM
ceramic tile to wood floor threshold bjs Flooring 23 11-28-2008 09:35 PM
