Old 08-17-2011, 11:12 PM   #1
Wood Laminate flooring
Does wood laminate floor or even vinyl floor contains any harmful substance like asbestos?
Saghir is offline   Reply With Quote
Old 08-18-2011, 12:15 AM   #2
Have a look:
http://www.inspectapedia.com/sickhou...estoslookB.htm
Asbestos is usually found in vinyl tile laid before the late 70s. I believe its use was banned in the US in 1978, so if you know your floor is newer than that you should be good.
If you want to be 100% sure you can get a test kit (I got one from Ace hardware for $20 or so). The kit comes with prepaid envelope, you mail in a sample of the flooring and they email you a report on its contents.
If you google asbestos flooring you'll find there's a ton of information on the subject.
mfc133 is offline   Reply With Quote
laminate wood flooring - after installed reds_21 Flooring 6 12-04-2009 08:22 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 08:19 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
Newbie w/a flooring question Laminate v. engineered wood UNCgal91 Flooring 2 08-25-2008 08:29 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 10:01 AM
