Wood Floors Separating? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 01:59 PM   #1
Rewards Points: 154
Wood floors separating?
Hi All,
It's been a few months since we got our new hardwood floors put in. Now, some of the floor boards seem to be separating. What can be causing this? We had our contractor install the new floor on the original subfloors which is not large pieces of plywood but the long skinny pieces of wood. The new hardwood floors are 3/4" tongue/groove solid wood and he did use a floor nail gun. In the beginning all the floors were nice and tight but now there are some areas that are separated by as much as 1/8". I'm thinking the old subfloor is moving? Because the new hardwood floor cannot move even though it's separated. SOme of the hardwood floors are even cracking.
llckll is offline   Reply With Quote
Old 01-10-2012, 02:03 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Sounds like he didn't let the product "acclimate" before installing.
And going over the old tongue and groove probably wasn't a very good idea either. Makes for an unstable underlayment.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-10-2012, 02:07 PM   #3
Rewards Points: 154
True, he didn't let it acclimate. But I also heard this is normal because the air is dry in the colder months. I'll wait and see if they go back to normal in the spring and summer.
What do you mean go over the old tongue and groove? This is new hardwood floor. Old hardwood was ripped out.
Old 01-10-2012, 02:17 PM   #4
Disabled wood vet
titanoman's Avatar
Oh. You mean the original floor is planking, probably run on a diagonal?
Still not good as the planking can expand and contract, as plywood can't.
Old 01-10-2012, 02:18 PM   #5
Rewards Points: 154
Yeah, oh well. It is what it is.
Old 01-10-2012, 02:21 PM   #6
Civil Engineer
Rewards Points: 4,938
First off, you said that the installer, per your direction, installed the hardwood above the original subfloor, which you said was "long skinny pieces of wood". Perhaps the original subfloor was tongue and groove subfloor, maybe just 1x4 boards. In any case, it is more common to install hardwood above sheathing, which is typically plywood. Plywood is somewhat more dimensionally stable than softwood dimensional lumber.
That said, hardwood certainly moves dimensionally with changes in relative humidity in the air. My hardwood floors are oak, and in the winter there are commonly gaps up to 1/8 inch between some of the boards, which disappears in the summer when the relative humidity is higher. This is pretty common, depending on where you live, and if your house is conditioned (mine is not).
Old 01-10-2012, 02:24 PM   #7
Rewards Points: 154
Yes, I meant the original sub floor. It was planking and 1x4. It wasn't tongue and groove sub floor. I believe the house was built in the early 1920's and it's probably the original sub floor and hardwood floors. I'll wait and see in the summer time to see if the gaps disappear. I read on the web that this is normal so I'm not that upset about it.
Old 01-10-2012, 02:55 PM   #8
Rewards Points: 2,212
What type of wood is your hardwood?
Also constant temp and humidity are good for wood floors. If your temp swings and your humidity goes up and down you will likely have problems.
mae-ling is offline   Reply With Quote
Old 01-10-2012, 02:56 PM   #9
Rewards Points: 154
3/4" solid acacia wood.
Old wood floors BungalowBaby Flooring 6 02-11-2012 01:55 PM
Refurbishing wood floors? DanSharRentals Flooring 2 04-08-2011 04:14 PM
Easy way to reseal (?) wood floors? boinsie Flooring 3 04-26-2010 07:52 AM
Between coats of polyurethane on wood floors, how do you get up the dust? proofer Painting 1 04-07-2008 07:27 PM
Polyurethane on wood floors -- What is this "wet edge"? proofer Flooring 1 04-06-2008 08:08 PM
