-   -   wood floors in bathroom? (http://www.diychatroom.com/f5/wood-floors-bathroom-6527/)
elementx440 02-16-2007 01:28 AM
Just wondering, are the current hard wood/simulated woods suitable for installation in a bathroom in regards to the moisture or water on the floor? Will it cause warping? I'm talking about the prefinished stuff from the local hardware suppliers...
AtlanticWBConst. 02-16-2007 07:10 AM
Generally...hardwood is not a well recommeded choice for bathrooms. Simply put: Wood and water don't mix well.
If using hard wood, it is vital that all joints be TIGHT and there should be several + layers of clear sealant applied to completely 'seal' the floor.
Laminates: If installed per manufacturer's specifications most will cover it under their warranties (i.e.-dupont flooring).
Laminate floor planks are really a 'picture' of the wood that they are supposed to 'mimic' or represent. The core of a laminate plank is full of 'water-proof' resin. On top of the 'wood picture' surface is a melamime protective coating. Thus, it tends to be more durable than wood if installed in a bathroom.
(FWIW - We have installed laminate flooring in bathrooms and kitchens...after carefully checking with each manufacture's specs.
Bathrooms require the toilet to be placed 'on top of' the flooring, like you would with tile work. Clear silicone needs to cover all exterior edges...to keep any possible moisture out. This last part is usually required for warranty...)
Zero Punch 02-17-2007 01:59 PM
I've installed somewhere between 50 and a 100 powder rooms in laminate, engineered hardwood and solid 3/4 oak over the years only have had one water related problem, that was from a poorly installed wax ring toilet flange seal. I fill all expansion gaps with silicone and plenty of it.
I have never done a full bath but have torn several out due to water damage all due from tub shower over spray over flow
Floorwizard 02-17-2007 03:43 PM
water will affect wood or laminate unless it is mannington's ICORE.
Properly installed will give you more time to clean up.
that's about it.
