Wood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 09:26 PM   #1
wood floors
Length x weith= sq foot . Thats how much wood you need to buy is that correct. I was reading you should buy more than you need might have some pieces that are no good . when you put down wood floors do you have to pull the base board off the wall. What are some good brands of flooring .Does lumber liquadators carry good product.Dont know much about it I do know carpet sucks in high traffic areas.
cdundon4va is offline   Reply With Quote
Old 11-16-2009, 11:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes, length multiplied by width will give you the square footage. You then need to add for waste and culls. The more you spend on the product and the higher quality you buy the fewer culls you will have. Waste should be determined by the seller after he sees a plan of your area to be covered.
You can remove the baseboards and reinstall them after the floor is in or leave them and add shoe-moulding or quarter-round-moulding after the floor is in.
Lumber Liquidators????? You been watching too much Ty Pennington!
XXX
Old 11-17-2009, 06:18 AM   #3
For a straight rooms, no jumps or turns, I usually add 5%. But you usually have to buy full box lots, so you usually are covered.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
