Wood Flooring On Top Of Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 11:22 AM   #1
Wood Flooring on top of Concrete slab
I had a water leak last year and now I have a weird smell. How do I check if there is mold under to wood flooring?
Shijean is offline   Reply With Quote
Old 07-21-2012, 09:19 AM   #2
Rewards Points: 240
take the flooring up, and look at it.
Fix'n it is offline   Reply With Quote
Old 07-21-2012, 03:49 PM   #3
Rewards Points: 264
As the other person suggested the only real way to check for water is to remove some of the flooring. If you want to avoid this I would suggest running a dehumidifier in the area to help with drying.
Awoodfloorguy is offline   Reply With Quote
Old 07-24-2012, 07:26 PM   #4
Any swelling? If not the dehumidifier is your answer, keep an eye on floor for shrinkage once dry.
Iflooru is offline   Reply With Quote
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 01:20 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 08:37 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 02:16 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
