Old 03-24-2006, 08:01 PM   #1
diy'er
la15ota's Avatar
wood flooring over slab foundation
What would you recommend for a wood flooring over a slab foundation. We are interested in using solid, engineer or laminate. What manufactures/brands are would you consider?
la15ota is offline   Reply With Quote
Old 03-24-2006, 09:42 PM   #2
Contractor
Need more info on the slab. Where are you? Possible groundwater infiltration (basement)?
Teetorbilt is offline   Reply With Quote
Old 03-24-2006, 11:37 PM   #3
diy'er
la15ota's Avatar
This is in northern California and not for a basement.
Old 03-25-2006, 03:49 PM   #4
Floorwizard's Avatar
Kahrs is the best engineered wood in the world IMHO.
But there are many other manufacturers you may like.
It needs to be floated over a 6 mil poly.
Floorwizard is offline   Reply With Quote
Wood Flooring etc emptee A Flooring 1 08-15-2007 11:57 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 07:21 AM
I need help Re: Poured Slab Foundation - Moved to Plumbing alextina Plumbing 6 04-19-2007 05:35 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
