Wood Flooring Over Curved Concrete Steps - Flooring - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 01:23 PM   #1
Question
Wood flooring over curved concrete steps
I have a sunken living room which we love. However, we have three different steps into the living room that are all curved and it's poured concrete.
There is currently carpet covering the steps and we'd like to lay hardwood or laminate down. How do we deal with these steps?
Do you build the wood step over them? Hire a concrete cutter? Help. Ideas please.
floridagirl73 is offline   Reply With Quote
Old 02-14-2012, 01:28 PM   #2
rditz's Avatar
can you provide pictures??
what is the tread and riser dimensions??
what do you mean by curved??
rditz is offline   Reply With Quote
Old 02-14-2012, 01:45 PM   #3
I took a picture, but not sure how to upload it.
The front of the step is rounded. Think semi-circle.
Not sure the answers on the other questions. Sorry.
Old 02-14-2012, 01:51 PM   #4
Old 02-14-2012, 01:56 PM   #5
rditz's Avatar
ok, i get it..
was it you intention to keep the step curved??
Old 02-14-2012, 01:57 PM   #6
rditz's Avatar
[quote=rditz;853413was it you intention to keep the step curved??[/quote]
also, is the top step curved?? (hard to see in the picture)
Old 02-14-2012, 02:00 PM   #7
There is only one step. The second step is the floor into the dining room and kitchen (under construction right now). That is flat.
Old 02-14-2012, 02:09 PM   #8
rditz's Avatar
ok, so then what I think I would do is cut a piece of plywood (1/2" or 5/8") into a rectangular shape that covers the curved step and over hangs the curve enough for some framing. then build some framing to support the over hanging edges. glue and tap-con it in place and then cover it with your choice of hardwood or laminate as you would with a normal wood sub-floor.
because it is a fairly deep step, there is room for you to build a fascia to face the upper riser, you can top it with plywood to match your upper floor.
The Following User Says Thank You to rditz For This Useful Post:
floridagirl73 (02-14-2012)
Old 02-14-2012, 02:14 PM   #9
That was exactly what I was thinking too...THANK YOU!!
Old 02-14-2012, 02:19 PM   #10
rditz's Avatar
send a picture when you are done.
Old 02-14-2012, 02:24 PM   #11
Sure thing! I have to finish the kitchen first. lol
Old 02-20-2012, 12:58 PM   #12
It's always something
Rewards Points: 150
This is interesting. I'd love to see the 'after' photos myself.
SingleGuy is offline   Reply With Quote
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 09:35 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 12:49 PM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 04:47 PM
