Wood Flooring Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2008, 10:34 AM   #1
Wood flooring over concrete
I have some 3/4" finished oak flooring i was going to sell to a buddy of mine. His installer said he could not put that thick of wood over concrete. Is this true?
sedwick is offline   Reply With Quote
Old 04-24-2008, 10:28 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 232
YES. Kinda hard to nail into concrete.
JazMan is online now   Reply With Quote
Old 04-28-2008, 10:51 AM   #3
I thought you glued it to concrete? If not whats the glue that they sell with this stuff used for?
Old 04-29-2008, 04:42 PM   #4
Can anyone enlighten me on this? Can i put 3/4" strip flooring over concrete, if not, what is the glue used for?
Old 04-30-2008, 02:12 PM   #5
Registered User
Termite's Avatar
You don't glue hardwood flooring! It is toenailed in the tongue with a special nailer. If it were glued down, the wood would not have any way to expand and contract with the humidity in the house.
Not a good idea to put it on concrete. A floating floor system would be a much better choice for a concrete floor.
Old 04-30-2008, 02:15 PM   #6
Underground Techie
sevver's Avatar
How about 1 1/2" of that pink foam, with 5/8 tongue and groove plywood over it, drilled and tapcon'ed in every foot or so, then install the hardwood over that.
sevver is offline   Reply With Quote
Old 05-01-2008, 12:29 PM   #7
Bruce flooring has instructions for glue down applications for 3/4" engineered flooring. Am i missing something here?
Old 05-01-2008, 01:48 PM   #8
From my recent dealings with several jobs gone bad my opinion is dont do it.
If you're going over a slab, use an engineered or laminate floor.
A 3/4" hardwood over a slab will only give you headaches.
Ash74 is offline   Reply With Quote
Old 05-02-2008, 03:04 PM   #9
Ok, so its not that you can't do it, just that its not a good idea.
Thanks for clearing that up.
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 07:21 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
