Wood Flooring Options - Flooring - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 05:17 PM   #1
I've got a few projects going on but need to get this one squared away and then the rest will go like domino's. Maybe.
My house is on a slab and I have 3 bedrooms that I want to remove the carpet and install wood flooring - as well as the rest of the house at a later date. I was leaning toward laminate but not sure which would be the better choice, laminate or engineered. I like the dark colored, hand scraped, wide plank look. I found a Pergo laminate at Lowe's I like, but would like some more knowledgeable opinions before I pull the trigger.
Laminate or engineered, and why?
Thanks.
OKDrew63 is offline   Reply With Quote
Old 07-11-2012, 05:20 PM   #2
Rewards Points: 14,278
Engineer, installed as a floating floor. Far more stable, does not look like a cheap plastic floor, below grade install rated, adds to the valve of a home not lower it like laminite does.
rusty baker (07-11-2012)
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 05:57 AM
Wood Flooring in Basement - Yay or Nay mobiledynamics Flooring 5 10-01-2011 04:29 PM
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 07:46 AM
Finish options with wood putty? Whitmarsh Gal Carpentry 3 06-03-2011 07:05 AM
