Wood Flooring In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 10-10-2007, 11:07 AM   #1
Question
Wood Flooring in Kitchen
We are planning a remodel of our kitchen. We would like to use hardwood flooring in the kitchen and run it through to adjoining areas ie. family room, hallway. Our delima is with the laundry area and the dishwasher. What recommendations are there for hardwood floors in these areas? Should we use the hardwood in the areas up to the appliances, and place vinyl under the appliances?
Another option may be the existing floor. Currently there is ceramic tile in the kitchen and laundry room. We have planned on removing the tile. Should we just leave the ceramic tile under the appliances and use some sort of sealent and moulding on the edges of the wood floor?
Any suggestions or recommendations would be very much appreciated.
Calico is offline   Reply With Quote
Old 10-10-2007, 12:38 PM   #2
Calico,
I have Hardwood in my kitchen and in my laundry closet is tile. I placed a threshold between the tile and the hardwood. Under the dishwasher I just have the hardwood. When i did the hardwood I put about 4 to 5 coats of Polyurethane. That gives the floor great protection.
jscholl411 is offline   Reply With Quote
Old 10-10-2007, 04:46 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 412
It doesn't matter what you put under the dishwasher. I usually just leave it with only a subfloor and shim it up as much as possible so it can be pulled out easy if needed. But since you're doing a total remodel, use the same flooring. Do that area last, use odd pieces.
If the dishwasher ever develops a leak, it'll ruin your hardwood regardless what's under it.
Jaz
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 01:58 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 01:30 PM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 02:20 PM
