Old 08-23-2008, 04:19 PM   #1
Smile Wood flooring + animal excretement?
We have some oak flooring in an abandoned house that I was hoping to lay in our kitchen. When we went to get it, it has areas that are rotten with mold and a pile of animal feces on it as well (and probably urine too I'd imagine) anyway the moldy sections could be cut away and all of it would be sanded, stained and polyurathaned. The question I have- if the racoon or whatever urinated on this wood and it was absorbed (which I'm sure it would have been) would the 3-4 coats of poly prevent odor from occuring-like seal it in? I'm scared to go thru all the effort of laying and refinishing this floor only to have past animal excrements smell it up or discolor later. Dont' know what to do. Anyone know about this? Thanks!
annie68164 is offline   Reply With Quote
Old 08-23-2008, 05:38 PM   #2
Don't use the sections of wood that are damaged. Cut those sections out and use the cut ends along the walls.
I think, once you sand it down with a floor sander, the stained sections will be gone anyway. I don't think the sains and odor would go that deep into the wood. When you finish wood flooring with stain, it doesn't absorb in far enough where the sander doesn't get it all out.
KHouse75 is offline   Reply With Quote
Old 08-23-2008, 07:00 PM   #3
poppameth
Guest
Posts: n/a
Just in case you might want to thin some clear shellac and use it as a sealer before applying the Polyurethane. Shellac is about the only thing that will seal the odor if it's still present.
Old 08-23-2008, 08:57 PM   #4
Tread carefully...having moved into a condo where the dog urine penetrated the substrate and into the OSB subfloor, I've done a lot of research on the dreaded odour problem. If I were you, I'd conduct a 'test' of the remedial measures you're considering before committing to laying the entire floor. I'd also consider how long the house had been abandoned and subject to the urine--->1 week versus 10 years makes a big difference. Finally, put your nose to the floor. You didn't say whether it currently had an odour? I had my face in the floor for weeks before I considered it 'safe"
Janet is offline   Reply With Quote
Old 08-24-2008, 04:23 PM   #5
thanks for the good advice. the floor is very old maybe at least 60+ years. it's in OK shape (according to my not-so-picky hubby) except for the forementioned problems. to be honest I have not looked at it all. it's in a big pile and I know I saw racoon excrement on it. I just walked away thinking there's no hope but thought I'd ask. You're right I need to lay it out and estimate the total damage before getting too serious about it. I'm sure it will be a TON of work whatever the case may be.
More On This Topic
Alpaca Excrement Habits
Alpaca Excrement Habits by Expert Village
Alpacas are one of the few animals that like to go to the bathroom together. Learn more about the excrement habits of alpacas in this free animal care video. Read More »
Whether you've just adopted a short tailed or a Virginia opossum as a pet, you can train your opossum to use a litter box. Both opossum species are clean animals and both tend to choose designated areas to defecate and urinate. These qualities make... Read More »
My name is Elizabeth and I am speaking on behalf of Expert Village. We are going to talk about cage accessories for sugar gliders today. The cage accessories that are absolutely required for every sugar glider cage would be a water bottle (they will... Read More »
My name is Paige and today we are talking about the best way to clean your wood floors. There are several steps to cleaning your wood floors. What you want to do first is vacuum; sweep your baseboards on your wood floors picking up all the particles that... Read More »
Parquet floors are beautiful in the home but require a lot of work. They may not be the best option for those with small children or dogs. If you do choose to have parquet floors and a dog, train your dog well to prevent any messes on beautiful wood... Read More »
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 11:04 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 11:14 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 5 07-07-2008 10:33 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 05:29 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 03:04 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
