Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 08:51 PM   #1
Wood Flooring
My house has an above grade slab foundation. The concrete has been acid stained and sealed with several coats polyurethane. Can I use a glue down engineered flooring over this?
Sonyaeman is offline   Reply With Quote
Old 01-05-2012, 08:54 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
May have to remove the Poly.
The people to ask this question of are the adhesive manufacturers.
XXX
Old 01-05-2012, 09:00 PM   #3
Thanks, That's what I was afraid of! I love the acid stain floor and the finish is in great condition but.... it is dark,dark brown and I find myself sweeping and mopping daily and it still looks dirty.
Old 01-05-2012, 09:06 PM   #4
Rewards Points: 13,694
It can also be glued at the T & G and in effect making it a floating floor.
I'd lay down a vaper barrier first.
Check out some of the web sites of the manufactures and look up install instrutions.
Sonyaeman (01-05-2012)
Old 01-05-2012, 09:06 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
You could always add some area rugs.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 01-05-2012, 09:07 PM   #6
Hey Bud, Could I install Travertine over the poly, directly to the floor without any type of Duroc?
Old 01-05-2012, 09:08 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Again, the Poly would have to be removed.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Electric Outlets under wood flooring jeh154 Electrical 3 08-09-2010 10:05 AM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
