Wood Floor Stain Color - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 10:11 PM   #1
toolbelt Tina's Avatar
wood floor stain color
I am installing a utility grade oak floor for the cottage.There is a mixture or white and red oak. What type of stain should be used so red oak does not stand out as much?
Any thoughts would be appreciated.
Tina
toolbelt Tina is offline   Reply With Quote
Old 07-27-2009, 11:50 PM   #2
Wood Flooring & Carpentry
lawndart's Avatar
I've found that using Ipswitch Pine helps to blend the two species when trying to blend the two colors.
Hardwood Flooring Company / New York Flooring Installers
lawndart is offline   Reply With Quote
Old 07-28-2009, 01:23 AM   #3
Thanks lawndart;
how many coats? I have about 350 sq ft. What quantity would I require?
Tina
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Clear exterior wood finish for natural color orrd Painting 2 07-06-2008 04:38 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 07:54 PM
