Wood Floor Sanding - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 08:36 AM   #1
Wood Floor Sanding
I was told that if you put paint thinner on floor it would not gum up sand paper. It does not sound like a good idea to me or that it will not work. This floor needs 12 grit paper. Any comments?
albany is offline   Reply With Quote
Old 02-22-2012, 04:00 PM   #2
Too Short? Cut it Again!
Not a good idea to put thinner on the floor for any reason. It will not keep paper from clogging. Who told you 12 grit and why?
Are you doing this yourself and what type of equipment have you decided to use?
Drum sanders are the fastest but will not get near the edges and you can do a lot of damage in just a few seconds. Orbital floor sanders work slower but are much easier for diyers. They will take more paper in successively finer grits but you would have to try to screw up a floor. They will get up to the edges.
You should get a floor sanding book or two from the library or from Amazon or something and familiarize yourself with what to expect before you start. If you have a lot to do, you may find it cheaper to bring someone in to at least do the sanding. Be patient though, good floor people stay busy and have waiting lists. You don't want the bad hacks in your house.
Old 02-23-2012, 09:19 PM   #3
Sanding wood floor
I agree with the use of the orbital sander, much easier to control. I sanded my LR and DR floors, they turned out beautiful but my 1 regret was that I was in a hurry and wished I had put at least 4 layers of finish on, also I would suggest using the proper applicator or your finish will have small bubbles in it. A Great website with a how to is hometime.com
care41 is offline   Reply With Quote
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
