Wood Floor Recommendation For Radiant Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 12-26-2012, 04:20 PM   #1
Rewards Points: 12
Wood floor recommendation for radiant heat
Any recommendations for what type of wood flooring to lay over a radiant system? I'm hearing Bamboo works well..
TANKLESSTOMMY is offline   Reply With Quote
Old 12-26-2012, 06:35 PM   #2
Rewards Points: 744
I have no recommendations. However, this is an interesting read: http://www.hoskinghardwood.com/radiant-heat/default.asp
Seattle2k is offline   Reply With Quote
Old 12-27-2012, 05:46 AM   #3
Rewards Points: 12
Thanks. I've seen that article but I'm getting mixed answers as to whether you definitely need to use quartersawn
Old 12-29-2012, 11:24 AM   #4
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Based on your name, I'll presume that you're installing a hydronic system!? If so, quartersawn is the only one you should use, short of engineered. Most solid mfr's won't warranty their product over hydronic systems.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 01-03-2013, 03:56 PM   #5
Rewards Points: 12
Yes it's a hydronic system. I was actually looking into a solid bamboo. I've been told since bamboo is more stable than oak, maple etc.. it would be ok over radiant. I can't find quartersawn in the darker color family that the wife wants
Kiln Drying lumber with wood heat? rdpierce General DIY Discussions 5 12-27-2012 09:42 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
heat shield for wood furnace chillz911 HVAC 7 09-10-2010 08:38 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
