-   -   Wood floor recommendation for radiant heat (http://www.diychatroom.com/f5/wood-floor-recommendation-radiant-heat-167433/)
TANKLESSTOMMY 12-26-2012 04:20 PM
Any recommendations for what type of wood flooring to lay over a radiant system? I'm hearing Bamboo works well..
Seattle2k 12-26-2012 06:35 PM
I have no recommendations. However, this is an interesting read: http://www.hoskinghardwood.com/radiant-heat/default.asp
TANKLESSTOMMY 12-27-2012 05:46 AM
Thanks. I've seen that article but I'm getting mixed answers as to whether you definitely need to use quartersawn
warmsmeallup 12-29-2012 11:24 AM
Based on your name, I'll presume that you're installing a hydronic system!? If so, quartersawn is the only one you should use, short of engineered. Most solid mfr's won't warranty their product over hydronic systems.
TANKLESSTOMMY 01-03-2013 03:56 PM
Yes it's a hydronic system. I was actually looking into a solid bamboo. I've been told since bamboo is more stable than oak, maple etc.. it would be ok over radiant. I can't find quartersawn in the darker color family that the wife wants
