Wood Floor Problem-Surface Wearing Off - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 06:12 PM   #1
Wood floor has a problem where the sun has lightened up area, and surface is wearing off in some areas.
Please look at pics, and I would appreciate your help. Thank you.
Wood Floor Problem-Surface Wearing Off-woodfloorproblem-001.jpg   Wood Floor Problem-Surface Wearing Off-woodfloorproblem-002.jpg   Wood Floor Problem-Surface Wearing Off-woodfloorproblem-003.jpg
needhelpplease is offline   Reply With Quote
Old 01-09-2010, 06:36 PM   #2
How old are the floors? did you have them installed? looks like a possible defect in finish
Old 01-09-2010, 06:49 PM   #3
Floor problems
Hi, thanks for your concern.
Floor was professionally installed. @ 5-8 years old. The Sun beats down on this area daily. Remainder of floor is fine.
Thank you.
Old 01-10-2010, 05:18 PM   #4
Thank you.
Has someone recoated that floor somewhere along the line? Only solution I see is to resand & refinish.
pinwheel45 is offline   Reply With Quote
Old 01-13-2010, 07:34 PM   #5
msv
Hardwood pro
msv's Avatar
if you still have the information, you might still be under warranty... nowadays, they offer up to 25 years finish warranty.... looks like the finish is peeling off... any spills of any chemicals?????
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Old 01-15-2010, 09:10 AM   #6
Get out of the box!
Rewards Points: 260
Looks like a good old fashion Bruce hardwood !
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Old 01-16-2010, 01:58 PM   #7
Isn't that an oxymoron? Good & Bruce in the same sentence.
Old 01-16-2010, 04:31 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 388
You've already identified the problem. "The Sun beats down on this area daily. Remainder of floor is fine."
You are supposedto protect wood, vinyl, carpet and other fabrics from the sun.
Jaz
Old 01-17-2010, 06:42 PM   #9
was it prefinnished or did the sand and finnish?
just tile is offline   Reply With Quote
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 05:04 AM
Been looking at some Wood Burning Stoves SELLC HVAC 17 10-20-2009 09:06 PM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 03:48 PM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 09:14 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
