Old 08-04-2009, 06:41 PM   #1
Wood Floor in my new shed
Hello everyone,
I just recently had a shed built by Agway in my town that im going to use to store my Honda Goldwing, a garden tractor, and a push mower in. I'm concerned with the wood floor in it getting ruined from moisture from tires, oil(hopefully not from the wing) and grass clippings. My question is what if anything should I use on the floor to seal or protect it from those things? My original thought was the coating for garage floors however that apparently won't adhere to wood, so my next thought was to use Thompsons water sealant and then apply floor paint on top of that with some sand mixed in for traction. My wifes uncle that owns a gypsum flooring business said that he didnt think it was a good idea because it would trap moisture underneath the shed and the floor would rot from the bottom up. I have looked into that rubbery/vinyl flooring for garages however I'm not really ok with sinking another $500 into this shed if i dont have to. The shed is built on 4X4s and is sitting on part of my gravel driveway.
Thanks in advance.
butlerguy1990 is offline   Reply With Quote
Old 08-05-2009, 09:25 AM   #2
Is your shed elevated or sitting on the ground?
Tess is offline   Reply With Quote
Old 08-05-2009, 12:09 PM   #3
It is elevated 4" inches off of the ground. The shed is built on 4"4"s that run the length of the shed.
Old 08-07-2009, 10:37 AM   #4
4" sounds low
In my area I would expect the floor to rot painted, sealed, or not
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
