Wood Floor Finishing Question: - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 09:50 AM   #1
I have the original oak floor in a fiftie's home. The floor was refinished by the previous owner. I did some tile work on a hearth and taped off the surrounding floor to protect it. Upon completion, the tape lifted off the newer polyurethane finish leaving very noticeable marks.
The floorboards themselves look fine. I would like to remove just the polyurethane finish. Is this possible to do?
Maybe using a rotary floor buffer with a screen?
Some type of chemical?
Any ideas or suggestions greatly appreciated.
minneapolis1 is offline   Reply With Quote
Old 09-29-2008, 10:03 AM   #2
Floor Finishing
Hi There, Looks like your going to need to re-sand the area, as far as i know there is no way of removing poly without having to re-sand, I am a floor sanding and finishing Op with ten years in the trade, you may be able to do just a section but it will come up lighter in colour but will darken down with age. I found a great website that showed you how to sand wood floors, don't know if it will be any help to you, http://www.floor-sanding-world.com
theparks is offline   Reply With Quote
Old 09-29-2008, 04:41 PM   #3
SM1
SandMasters ProFloorCare
SM1's Avatar
what kind of tape did you use? cause you may be looking at a peeling floor in the future and may want to think about resanding the entire floor. If someone recoated the floor and didn't abrade the surface first, or if the floor had any wax or chemical buildup...the coat prolly won't adhere for long.
SM1 is offline   Reply With Quote
Old 09-30-2008, 07:12 PM   #4
SM probably knows better but if tape pulled up the poly, seems something is wrong. Poly is a son of a gun to get off when you sand it, tape shouldn't of hurt it, just my guess anyway
DUDE! is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
interior wood trim, surface preparation question copacetic Painting 3 04-25-2008 07:52 PM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 09:27 AM
