Wood Floor Direction In Adjoining Rooms - Flooring - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 04:07 PM   #1
wood floor direction in adjoining rooms
In my kitchen/dr I have 100 yr. old solid oak flooring running east-west. Am planning to have wood flooring installed in adjoining living room. My question is-does it have to be installed east-west or can it run north-south and look good? Thanks
suerosedale is offline   Reply With Quote
Old 12-09-2008, 04:11 PM   #2
I would install it in the same direction. It will flow better.
hrjrkr is offline   Reply With Quote
Old 12-09-2008, 09:50 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
Hardwood should be installed across the joists, not with the joists. If it was engineered I guess it wouldn't matter in that regards? You could install regular hardwood parallel with the joists, but you'd want to add another layer of underlayment first to stiffen the floor, otherwise you may get waves in the floor. (Dips between joists.)
Jaz
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
adjoining rooms getting out of square on engineered wood installation jencastro Flooring 5 09-22-2008 10:58 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Design rules for wood floors in adjacent rooms chrish Flooring 1 09-10-2007 08:04 PM
