Wood Floor Buckling - Flooring - DIY Chatroom Home Improvement Forum
Old 10-02-2012, 07:01 PM   #1
wood floor buckling
my home is a100yrs old & my floor is buckling in certain areas. My wood floor is only floor, no sub, how can it be repaired?
Khaney is offline   Reply With Quote
Old 10-02-2012, 08:17 PM   #2
Rewards Points: 13,300
Any old house I've every worked on has at least a few of these problum
joist are under sized for the span, there spaced more then 16" apart, fungus damaged, insect infested, split or cracked.
Everyone is fixed on a case by case by basis.
Most if not all of the fixes are done below the floor not on top.
Most will need at least need more footings and a beam ran down between the piers that are in there now to lift and spread out the load.
Old 10-02-2012, 08:57 PM   #3
Rewards Points: 150
Probably the same as mine....they ran the flooring the same way they ran the subfloor, instead of perpendicular. Fortunately I have no buckling, but it's still installed wrong.
Squished is offline   Reply With Quote
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
