-   -   wood floor buckling (http://www.diychatroom.com/f5/wood-floor-buckling-158738/)
Khaney 10-02-2012 06:01 PM
wood floor buckling
my home is a100yrs old & my floor is buckling in certain areas. My wood floor is only floor, no sub, how can it be repaired?
joecaption 10-02-2012 07:17 PM
Any old house I've every worked on has at least a few of these problum
joist are under sized for the span, there spaced more then 16" apart, fungus damaged, insect infested, split or cracked.
Everyone is fixed on a case by case by basis.
Most if not all of the fixes are done below the floor not on top.
Most will need at least need more footings and a beam ran down between the piers that are in there now to lift and spread out the load.
Squished 10-02-2012 07:57 PM
Probably the same as mine....they ran the flooring the same way they ran the subfloor, instead of perpendicular. Fortunately I have no buckling, but it's still installed wrong.
