Wood Floor Around Railing - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 10:10 AM   #1
Wood floor around railing
Could someone please help me with how to lay flooring (2.25 x .75 t&g HW) around this railing?
I plan on placing landing tread around the exposed floor edge as you can see in the second photo. The tread is around 4" deep so it's looking like I'll have to rip that or find some way to notch it so it can be placed over the area where it attaches. Does this make sense?
The other question involves the current piece of trim resembling stair nose. I assume I'll need to square off the end of that as well.
I would GREATLY appreciate hearing from people as to how they would solve this problem.
Thanks folks!
Brian
Wood floor around railing-rail-close.jpg   Wood floor around railing-railing.jpg
Badger_DIYer is offline   Reply With Quote
Old 03-24-2009, 11:18 AM   #2
Floorwizard's Avatar
If this is solid wood and your naling it down (sounds like it) then you can remove railing and reinstall it after the wood is down.
No need to go (around) it
Floorwizard is offline   Reply With Quote
Old 03-24-2009, 11:40 AM   #3
Thanks, Wiz. Are there coverings for where it would attach to the wood? That would be a little unsightly, IMO.
b
Old 03-24-2009, 12:47 PM   #4
Remodeling Contractor
It goes on over the wood. Not unsightly if you remove the white paint and repaint the railing.
Old 03-24-2009, 04:11 PM   #5
nope...looks good with a nice repaint.
Consider using the speckled paint instead of solid black....I like it at least...
Tags
finishing , hardwood flooring , railing , subfloor , trim
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
painting a wood railing monte7 Painting 1 05-27-2008 08:55 PM
Interior Wood Railing mahjohn Carpentry 2 07-05-2006 06:47 PM
