Old 03-12-2009, 12:07 AM   #1
Question
Wood Floating floors on heated concrete
Can you tell me what kind of underlay/pad you would recommend for putting under a wood floating floor on underfloor heated concrete ? Do not want to insulate the wood from the concrete but want to distribute the heat evenly
So can't use the foam and foil underlay that is normally used
yours Tim
baywicks is offline   Reply With Quote
Old 03-12-2009, 09:58 AM   #2
The flooring manufacturer will have a specific way to do it and if you don't they won't stand behind their warranty. So contact the flooring company as they often have different methods.
Old 03-12-2009, 03:22 PM   #3
Hi Jogr, The original flooring company is Chieftain but I can't find their site on the web ??
The flooring has been imported into New Zealand by a local lumber company and they are selling it here .... must people say you can just glue it down to concrete but our building department down here in Nelson NZ are a totally paranoid lot so will not allow glue down unless specifically allowed by the manufacturer ( or more like they just want to cover their ass in the case of any problems )
The supplier here tells me that " there is a special underlay for heated floors "
but has never used it and can't remember the name !!
I have done a bit of research and couple of other flooring companies in NZ say it can be done using 'radiant heat paper' and another one called "Soprema Velaphone" which appears to be an acoustical underlay to stop noise
Does anyone know Chieftain products and if they have a website ?
Thanks Tim
Old 03-13-2009, 07:31 AM   #4
ccarlisle's Avatar
You really have to know what you're dealing with when you come out and say: "glue down and concrete" in the same installation, and most of what you have to be sure of is what you can't see. Strength, humidity level, spalling etc...so IMO unless you know how that concrete is and how it will react to moisture, then a glue-down is questionable at best. So perhaps your building dept is CYA but on the other hand perhaps they know something you don't.
And that is to say nothing of how that moisture interacts with the heating system and how both relate to your 'unknown' flooring...how hot is the floor heating system anyway? is it hydronic? some systems don't let the floor get above 85 degF for a good reason.
ccarlisle is offline   Reply With Quote
More On This Topic
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
Learn materials needed for silkscreening at home and how to screen print a shirt in this free video on silkscreening, or screen printing, clothing. Read More »
Hi! This Is Shana Bethune on behalf of Expert Village and I am going to talk to you about how to reduce outside noise. Wherever you record, there is going to be noise coming in from outside like sirens, people yelling in the street or cars driving by so... Read More »
There is no reason to throw out a chair because of a loose chair rung. Fixing a loose chair rung is quick and easy to do. It is a great skill that allows you to fix flea market finds and garage sale cast-offs, or just to prolong the life of your existing... Read More »
You can do countless projects by simply using concrete mixed with varied additives. You will go about the project in different ways depending on exactly what you need to pour. Buy and add the appropriate additives per the instructions with your concrete... Read More »
Insulating wood floors krankykitty Flooring 6 10-31-2008 02:25 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 5 07-07-2008 09:33 PM
Self Leveling compound on hard wood floors?? Tbizzy2 General Discussion 3 05-22-2008 12:11 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
