Wood Deck - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 07:12 PM   #1
wood deck
I am in prosses of resealing my old deck. I have presure washed and sanded the deck. the planks on the deck have not faded the same and there are strong color mismatch. How can I get more uniform look on the deck when I seal it. I do not want to use solid sealer. please help.
mhdi63 is offline   Reply With Quote
Old 06-19-2011, 10:17 PM   #2
woodman58's Avatar
You did not give us alot of info to work with but, I will give it a shot. It sounds like in some areas the original UV protectant wore off quicker than in other spots lighten or even gray alittle. If this is the case the only way to get the entire surface to match is sand the entire deck. Then put a water proofing of some sort on it. Thompson's will work.
woodman58 is offline   Reply With Quote
Any wood prep product for cracks in deck wood? FrankL Painting 1 06-11-2010 12:20 PM
Staining vs just sealing preserved wood deck? Hossenfeffer Painting 1 05-28-2010 06:20 PM
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE! JLayman Building & Construction 3 08-07-2009 11:20 PM
sealing a very old wood deck browneyesbloo Building & Construction 6 09-23-2008 10:47 PM
Help on Staining my wood deck thedirkus Painting 3 06-12-2007 09:28 PM
