Wood To Carpet Curved Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 07:44 PM   #1
Wood to Carpet Curved Transition
Hi,
I have this curved joint in a flooring project I'm finishing. I'm not sure what to do with it; it's not attached yet just trimmed to fit. A curved T molding would be the obvious solution, but it would be a custom piece and I also like the flush look. Is there a way to permanently attach the carpet as it now sits? The contractor flooring forum had a post mentioning a technique using a shim strip and final tuck under for the carpet, perhaps with glue or staples for reinforcement.
What do you think? Thanks in advance for any ideas.
DIYxFramer is offline   Reply With Quote
Old 10-16-2013, 10:06 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Z-bar will do that.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-16-2013, 11:46 AM   #3
K&B Designer
Live_Oak's Avatar
A Schluter strip can be snipped to follow that curve.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-16-2013, 01:23 PM   #4
Very cool looking!
clayduster71 is offline   Reply With Quote
Old 10-16-2013, 05:30 PM   #5
Thanks for the replies. I'll update the thread when I finish it off.
Old 10-17-2013, 01:18 PM   #6
Rewards Points: 81
Can this be done on concrete? I"m using floating, click lock vinyl planks that call for a 1/8" expansion gap. The planks are a little less than 3/16" thick. Would I just butt the planks against the carpet? Does the carpet or vinyl planks need to be done first?
OhioDon is offline   Reply With Quote
Old 10-17-2013, 07:26 PM   #7
Rewards Points: 182
I would do the planks first.
Old 10-22-2013, 07:42 AM   #8
Rewards Points: 81
My planks are floating, no adhesive to each other and not glued to the floor. Will the rolled carpet hold the ends of the planks down?
Old 10-22-2013, 10:13 AM   #9
Rewards Points: 182
No. You will need a transition strip. The edge of the planks go under it, leaving a gap underneath. Carpet goes under the other edge.
Old 10-22-2013, 10:23 AM   #10
Rewards Points: 81
Hmmm.... Can I get a flexible strip or do I need to run straight lines?
The picture in the original post, is shown without a strip. Is that floor probably fastened to the subfloor?
Old 10-22-2013, 01:09 PM   #11
Rewards Points: 182
I would hope it is fastened, otherwise they will have problems.
Vinyl to Carpet Transition on concrete ds28 Flooring 6 04-25-2013 12:44 PM
tile to carpet transition qchawkfan Flooring 8 04-25-2010 11:25 AM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Carpet transition question Richo Flooring 2 04-25-2009 11:40 PM
Wood floor or carpet? darsunt Flooring 9 08-03-2007 11:12 PM
