Wonderboard Problem? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 07:15 PM   #1
analogmusicman's Avatar
Rewards Points: 560
wonderboard problem?
I just got finished laying down some wonderboard lite and darn it, there's a noticeable ridge at the seam of 2 pieces. (one piece is about 1/16th higher than the other. the floor is level so all I can think of is that I got a "bum" sheet of wonderboard which isn't exactly 1/4 in. (I'll measure later)
the question is whether I can make up the diff. with thinset when I tile or does that piece of wonderboard have to come out? this "ridge" is right at the doorway otherwise I'd forget it.
tnx,
analogmusicman is offline   Reply With Quote
Old 03-23-2013, 07:23 PM   #2
Rewards Points: 13,458
Put a dust mask on and sand it to blend it in.
If it's truly 1/16 it's not an issue.
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
